door actuator relays location?
2doger
Posted: March 07, 2009 at 12:08 PM / IP Logged
I have a 96 Subaru Legacy Wagon and Clifford G4 Polaris Alarm. The doors no longer unlock (but do lock). It is an actuator system, and after swapping to a spare actuator realized this must be a relay problem (after looking at the diagrams on the site, there must be two). I can't for the life of me find the relays. The Clifford main unit is deep behind my dash, and was installed by a professional (who has long since gone out of business). Anyone have any insight on standard locations for the relays?
Posted: March 07, 2009 at 12:42 PM / IP Logged
Could be anywhere inside the dash or driver's kick panel. I'm assuming one actuator was used, in any case follow the lock unlock wires, GREEN / WHITE and ORANGE / white from the alarm unit to the relays. This is assuming aftermarket actuators. In the UK it was a 1 wire system which would only requre ONE relay on the lock side.
2doger
Posted: March 07, 2009 at 12:46 PM / IP Logged
Yes, they are aftermarket actuators. It is packed so tightly in there, I could not follow the wires. How are they usually mounted?
I am not sure if there is one or two relays, as I can't find them!
Posted: March 07, 2009 at 2:44 PM / IP Logged
If you can control the locks from the driver's door by turning the key, look for a BLUE relay,  its actually a  twin relay with a built in timer that shuts the coils after 1sec.  Otherwise look for two black bosch type relays.
2doger
Posted: March 07, 2009 at 8:11 PM / IP Logged
Found them, thanks. So now I need to find out where I can buy these? They are 5 pin Bosch 20/30A.   Radio Shack has 4-pin only and my local auto parts store does not carry them.
loneranger
Copper - Posts: 572
Posted: March 08, 2009 at 3:47 AM / IP Logged
Your local auto parts store does carry them, as generic 20/30/40 amp SPDT.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted: March 08, 2009 at 4:45 AM / IP Logged
LoneRanger is quite correct as usual, sorry about the cap not being chemical, the other name for that relay is Type 87b or type 87b five pin.
Posted: March 08, 2009 at 4:46 AM / IP Logged
Sorry I meant 87a, b is a completely different animal
2doger
Posted: March 09, 2009 at 10:51 PM / IP Logged
Thanks all!
loneranger
Copper - Posts: 572
Posted: March 10, 2009 at 4:22 PM / IP Logged
howie ll wrote:
.. sorry about the cap not being chemical, ..
I was just being anal.
On another note, an old theory has been proven, in the predicted electrical model. Google "memristor theory discovered". It is quite an adavncement for electrical theory and design. It's going to have grand implications in the near future. It's kind of like solving the 'Unified Field Theory' model, for electronics. Well not that enlightening, but you get the point.
