no accesory wire ?
grundler1975
Member - Posts: 29
Posted: March 21, 2003 at 3:34 PM / IP Logged
I have a 97bmw 328I convertible and there is no accesory wire to hook up the orange satellite relay to for the remote start. all accesories do come on when I try to remote start. Is this wire nessecary? There is nothing in the diagrams that shows and accesory wire is there?(I mean for the remote start relays not the rest of the car.)
auex
Platinum - Posts: 5,041
Posted: March 21, 2003 at 4:07 PM / IP Logged
If the vehicle has no wire at the ign harness then the computer probably turns it on, so then there is no need to wire the rs acc output to the car.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
grundler1975
Member - Posts: 29
Posted: March 21, 2003 at 6:50 PM / IP Logged
can I use that wire to run all of the alarm accesories that I bought like a 545t and a 530T? for the accesory turn on?
auex
Posted: March 21, 2003 at 7:47 PM / IP Logged
Uh... those need to be hooked up to a constant source of power, unless you only want them to work when the remote start is active.
grundler1975
Member - Posts: 29
Posted: March 21, 2003 at 10:30 PM / IP Logged
i thought a couple wires said accesory turn on but could be wrong
auex
Posted: March 21, 2003 at 11:07 PM / IP Logged
The orange wire from the sattelite relay only provides power when the remote start is active. What you are probably thinking about is either the 2nd channel or channel 4 output(assuming your alarm is dei).
