2004 celica whine
x-nautix
Posted: March 12, 2009 at 10:49 PM / IP Logged
Ahoy hoy
Installed a DD stereo into a 2004 Toyota Celica GTS with the JBL amplified system. Use a BHA8113 for the install. There is terrible alternator whine when the stereo is on. It does not get worse when the gas is pressed and doesn't get louder when the volume is turned up. Ive tried resistors to reduce the signal output and re-grounding the unit. Ive heard from fellow installer that is you ground the signal ground it will help. What are my options? Amp Bypass?
DYohn
Platinum - Posts: 10,741
Posted: March 13, 2009 at 10:09 AM / IP Logged
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
