528t pulse timer converted to time delay?
mikef5000
Member - Posts: 10
Posted: March 14, 2009 at 8:24 PM / IP Logged
Hello! This is my first post here. I have an understanding about basic electronics, but no experience. Bear with me here, as I'm learning as I go.
WHAT I WANT:
A time delay relay. I want to delay the activation of the relay about 20 seconds after it first receives power. It will run off 12v DC, and I was going to use a separate SPDT relay because I'll be seeing close to 20 amp spikes at times.
WHAT I BOUGHT:
The 528T Pulse Timer.
Now, after a few hours of extensive screwing around. I've learned what I bought is not exactly what I want.
Also, thanks to the great search function on this site, I found what I want online (Amperite C Series Time Delay Relay), but the price seems a bit... excessive ...for what it is. ($35-$55 528t pulse timer converted to time delay? -- posted image. )
So I guess my question is...
Can I somehow use my 528T in combination with an SPDT to accomplish what I'm shooting for? Or is there a more affordable option than the Amperite C that will do what I want?
Thanks in advance!
mikef5000
Member - Posts: 10
Posted: March 14, 2009 at 8:26 PM / IP Logged
I forgot to mention, I'm not quite confident in my skills enough, nor do I have any of the needed tools, to assemble something myself.
Thanks!
ckeeler
Gold - Posts: 1,461
Posted: March 16, 2009 at 9:30 AM / IP Logged
what you are wanting to do can be done with the 528t depending on what it is you are trying to do. i can give you a very descriptive explanation if you can explain in more detail what it is you are trying to do. you will get more answers on your thread from others also as they will be able to better help with a solution, not only that, there may be more than one way to do what you want that someone else knows of, everyone skins their cat differently if you know what i mean.
mikef5000
Member - Posts: 10
Posted: March 16, 2009 at 11:33 AM / IP Logged
Alright, the ugly details:
I'm wiring up an HID headlight to my motorcycle. I have a switched circuit already set up for it, but I need to delay the HID starting for about 20-30 seconds after the circuit gets power.
I've got the 528T and a standard SPDT relay to work with.
Thanks!
ckeeler
Gold - Posts: 1,461
Posted: March 16, 2009 at 12:05 PM / IP Logged
on the 528t connect the black and BLACK/ white wire together and ground them, connect the red wire and yellow wire to your switched circuit (assuming your switched circuit provides 12v+ out), connect the orange wire to 86 on your relay and ground 85. the brown wire will not be used. now just play with the adjustment screw until you get the time you want/need. when you turn on your switched circuit it will trigger the 528t for whatever amount of time you have it set for, then once it returns to its normal state(after it times out) it will send power to your SPDT relay triggering it and sending power to the light.
mikef5000
Member - Posts: 10
Posted: March 16, 2009 at 12:14 PM / IP Logged
WOW! I'll wire it up tomorrow and report back!
I can't thank you enough!
mikef5000
Member - Posts: 10
Posted: March 18, 2009 at 5:28 PM / IP Logged
I had to switch the Orange wire with the Brown Wire, but in the end it worked out perfectly! Thanks!!!
Here's a quick sketch-up of the wiring.
Single 35 watt HID:
Double 35 watt, or 55 watt HID's:
mikef5000
Member - Posts: 10
Posted: March 18, 2009 at 5:33 PM / IP Logged
Try this again...
Single 35 watt setup:
Double 35 watt or 55 watts:
ckeeler
Gold - Posts: 1,461
Posted: March 18, 2009 at 5:54 PM / IP Logged
ooops, my bad. sorry. i was going by memory because i didnt have one in front of me. glad it worked.
