amp goes in protect mode.
highhilltx
Member - Posts: 11
Posted: March 16, 2009 at 12:34 AM / IP Logged
i have a hifonics 1500 brutus class d on 4 kicker cvrs 10s dual voice coil. the systems plays good, amp does not even get warm, if i play my music, cut my car off, and turn it back on the amps goes to protect mode. whenever the amp starts playing again, it plays the music fine, never cuts off in the act of music playing, but if i turn da car off, and turn it back on the amps goes to protect. pls help.
Platinum - Posts: 13,725
Posted: March 16, 2009 at 6:51 AM / IP Logged
Where did you get power for the remote terminal of the amp?  Factory deck, aftermarket deck??
highhilltx
Member - Posts: 11
Posted: March 16, 2009 at 1:05 PM / IP Logged
i got a jvc El Kameleon KD-AVX44 A/V. i got the remote to the amp, on 'remote out'  from the radio, i also have a audiocontrol epic 160 hooked up with the radio. i too have it on the remote out. i know it has to be something with the remote, because whenever the amp is in protect mode, my epicenter bass/power light blinks together, unless something is wrong with the epic, causing it tomess with the remote on the amp
soundnsecurity
Gold - Posts: 2,720
Posted: March 16, 2009 at 3:34 PM / IP Logged
move the amp remote wire to the red wire behind the radio and see what that does.
highhilltx
Member - Posts: 11
Posted: March 16, 2009 at 9:53 PM / IP Logged
thank u, i also did that today, and its still doing the same, i think something is wrong with da amp/ and the epic is getting a signal through the rcas causing it to blink with the amp
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
