09 scion xb
racerjames76
Silver - Posts: 581
Posted: March 19, 2009 at 5:53 PM / IP Logged
Did a 2009 scion xB the other day, and everything was correct except the door locks. All sources state
Power Unlock          PINK          (-)          IN HARNESS IN DRIVER KICKPANEL
               THIS WIRE REQUIRES A DOUBLE PULSE
     PowerLock          LIGHT BLUE          (-)          IN HARNESS IN DRIVER KICKPANEL
None of these wires tested with the switch, so i started probing every wire coming out of the door. Found that dark blue and yellow were direct negative from the switch.
Problem is, customer states that the alarm randomly doesnt respond, and then he used the factory remote to unlock, which set the alarm off. He couldnt get the alarm to respond, but finally it did. Also, now sometimes the factory fob only beeps and flashes the lights. It doesnt operate the locks. Everything seems to be fine. Switch always works, i assume nothing is messed up. I got a feeling this has a 3rd child safety wire. Any advice guys? Any other ways to find the correct blue and pink wires?
KarTuneMan
Platinum - Posts: 7,056
Posted: March 19, 2009 at 6:42 PM / IP Logged
Test with the key IN THE DOOR, not the switch!
Mike M2
Platinum - Posts: 2,652
Posted: March 19, 2009 at 6:43 PM / IP Logged
Yep, you have the wrong wires! Pink and light blue...
Mike M2
Tech Manager
CS Dealer Services
racerjames76
Silver - Posts: 581
Posted: March 19, 2009 at 6:51 PM / IP Logged
alright thanks guys, will check that out as soon as i get it back to test. Told the customer not to use the alarm for now.
racerjames76
Silver - Posts: 581
Posted: March 24, 2009 at 5:39 PM / IP Logged
Thanks guys, everything checked out as expected and no damage done. Working fine for 3 days now. 09 scion xb -- posted image.
