diode
rfhelp
Member - Posts: 31
Posted: March 23, 2009 at 2:18 PM / IP Logged
i was told to get a 1N914/4148 type diode from radio shack. I have found some on ebay one pack is the 1N914 and the other is 1N4148.
Are these the same diodes? I am wanting to protect a 12vdc system from relay spike.
Platinum - Posts: 13,726
Posted: March 23, 2009 at 2:42 PM / IP Logged
They are essentially the same diodes.  However, I would highly recommend using a 1N4001 diode for your application.   The voltage spike from the collapsing coil of a relay can be pretty violent.  The 4001 is a 1 amp device, the 4148 or 914 is a very small device.  1N4001 or 1N4007 or any number in between would be suitable for your need.
rfhelp
Member - Posts: 31
Posted: March 23, 2009 at 2:58 PM / IP Logged
Thanks for the quick reply.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
