aps 785 issue
gr3atm3linko
Member - Posts: 28
Posted: March 23, 2009 at 11:27 PM / IP Logged
I just installed an old audiovox aps 785 alarm/start combo in a '97 saturn sl2. it still works great, a little hard to program the installers options but I've used worse. The problem is that the oem shock sensor causes the alarm to go off when it's armed during remote start.Oh, I ordered 2 new transmitters for it, how many can I program to it and how do you program them?
gr3atm3linko
Member - Posts: 28
Posted: March 23, 2009 at 11:30 PM / IP Logged
Oh yeah, can you get a 2 way upgrade for this and what year is this unit from, thank you.
Chris Luongo
Platinum - Posts: 3,746
Posted: March 24, 2009 at 9:07 AM / IP Logged
1. The search feature will find you the information on how to program the remotes.
2. Most of the plugs on the two-way are the same, but not all.
Not only is the antenna different, but so is the cable, so you'd have to re-run the antenna cable.
The plugs for the main ignition wires, shock sensor, valet switch, LED, doorlocks, and remote-start control switch are all the same.
They're located at slightly different places on the new brain, but they'll all plug in.
The harness that has the brake, parking lights, door trigger, trunk trigger, trunk release, starter kill, ground, and so forth......that one's different.
Whether you want to cut and re-splice the wires right at the brain, or disconnect all those wires from the car and re-connect the new harness, is up to you.
gr3atm3linko
Member - Posts: 28
Posted: March 24, 2009 at 10:35 AM / IP Logged
thank you, but do you know why the alarm goes off when it's remote started?
Posted: March 24, 2009 at 12:00 PM / IP Logged
If the shock sensor is external,  run a relay off the armed whilst starting wire and connect your shock sensor trigger across the NC relay contacts, 87a and 30,  that will do the trick.  Sorry do you mean GM factory installed shock sensor or Audiovox unit but then if you can find the OEM same rules apply or disarm factory alarm whilst remote starting.
gr3atm3linko
Member - Posts: 28
Posted: March 24, 2009 at 5:40 PM / IP Logged
I meant the shock sensor that came with the alarm, it plugs into the brain, and yet, no shunt when remote started. So I took your advice and relay isolated the trigger wire with 3rd ignition out, works fine now, thank you, but it will still go off if I turn the remote starter off.
gr3atm3linko
Member - Posts: 28
Posted: March 24, 2009 at 5:51 PM / IP Logged
I used to have an old dei 550hf, I put that in like, 8 different cars and never had this much trouble. Ironically, where I work, I do put quite a few aps 45bs in. But our starters and alarms are omega, which is crap, I know, but I have become very familiar with that flavor of crap.
