rca voltage
j_maxwell789
Posted: April 05, 2009 at 7:47 PM / IP Logged
Hi,
Basically I have a factory intstalled Amp that currently gets 2v from the factory Head Unit. I want to replace the Factory head unit with a JVC Head Unit with 5v RCA preouts, but I have to keep the existing amp.
My question is: Does the voltage of the preouts change with the volume the Head Unit is set to? Eg If I keep the volume low on the head unit, would the RCA voltage be less then the specs of 5v?
Any help would be great.
Cheers
Platinum - Posts: 13,724
Posted: April 05, 2009 at 8:39 PM / IP Logged
With the volume turned all the way down, there is 0 volts coming out of the RCA jacks of the radio.  As you turn the volume up the voltage increases.  You can connect the 5 volt radio to the 2 volt amplifier.  However if someone were to turn the volume of the new radio all the way up, it could get kind of loud.
j_maxwell789
Posted: April 05, 2009 at 11:30 PM / IP Logged
Ok thanks. Sounds like from what you said it should work as long as I keep the volume down on the head unit
