viper 5601 trunk release
littlemann49
Member - Posts: 7
Posted: May 04, 2009 at 2:20 PM / IP Logged
have a viper 5601 hooked up trunk release wire to a relay for trunk release soloenid it does not work with remote when i press aux button when i touch release wire to ground it works ok so wireing to relay is ok is there something in the programing witch makes it work cant seem to find anything in manual any one know please
petey
Big Dog
Gold - Posts: 1,265
Posted: May 04, 2009 at 2:40 PM / IP Logged
Are you using the RED / white from harness 1? Also, you need to press and hold the aux button for at least 5 seconds before it sends the signal.
Prepare your future. It wasn't the lack of stones that killed the stone age.
littlemann49
Member - Posts: 7
Posted: May 04, 2009 at 5:52 PM / IP Logged
hi thanks for the reply yes i used the RED / wht wire and yes im holding the aux button for 5 seconds still dont work i checked the cricuit if i touch a ground wire to it it works ok seems like control is not giving ground do u know if programing can affect that thank you
petey
littlemann49
Member - Posts: 7
Posted: May 05, 2009 at 10:33 AM / IP Logged
thanks for the help b.d. i found the problem i wired it wrong i was to lazy to take the harness i made apart but i had to and i found what i did wrong thanks for your help
petey
Friday, September 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
