skyline
msmart
Posted: June 03, 2009 at 5:32 AM / IP Logged
Hi guys, I'm intending to instal a Toad AI606  alarm in my Skyline R33 GTR, I'v done a few searches on the forum and can't find anything.
Does anyone have a wiring diagram for the Skyline, or a data/installation sheet for this car?
Any help appriciated skyline -- posted image.
jinstall
Copper - Posts: 67
Posted: June 03, 2009 at 3:12 PM / IP Logged
hey I did up a small system in an older skyline, it seemed surprisingly similar to an altima. nissan's generally try to stick with one idea it seems.
not sure what the system you're installing is, but it's pretty difficult to expect somebody in north america to have info on a non NA domestic market vehicle. if your system is just an alarm, or if your car does not have an immobilizer, I would just look up a similar year nissan and go with that info. of course you'll need to test all your wires, but it shouldn't be terribly difficult.
if it does have an immobilizer and you are installing a starter, you'll need to get a hold of some tech support and see if they can help you find information on the immobilizer. which unit will work with which software for your car. (just about guaranteed you can get an idatalink module to work, but you need to know what module to use, wqhat software, and what wires you'llneed to hook up to).
being that it is a nissan, it's going to have the same immobilizer system as some other nissan, again you just have to find out which one.
msmart
Posted: June 03, 2009 at 3:41 PM / IP Logged
Thanks for the reply, I'll look into it and see what ai can find out.
Mike
Posted: June 03, 2009 at 4:41 PM / IP Logged
Of course it doesn't qualify as a Cat 1 unless professionaly fitted, there's no UK spec on them, they were all grey imports, if I remember, you need an actuator in the driver's door for the  central locking, you need to run a wire from the switch in the trunk for the trunk (boot), either door will give you door trigger, cut ign and start in the ign switch lead, hood switch required, indicators prob GREEN/ YELLOW and GREEN/ black in floor loom at DKP. It's actually dead easy apart from the solenoid in the driver's door. Just plunge on in with a DMM. The alarm itself is pretty reliable with straight forward wiring, it fits nicely into the DKP. It comes from the same factory as Clifford/Viper product.
msmart
Posted: June 03, 2009 at 6:17 PM / IP Logged
Thanks Howie11, for the info, excuse my ignorance, but I'm not very good with  acronym's, what's DKM and DMM?
Cheers
MIke
joch1314
Copper - Posts: 301
Posted: June 03, 2009 at 6:52 PM / IP Logged
DKP-----driver's kick panel:  the location where you can find some of your wires and stash your brain
DMM-------Digital multi-meter:  you'll need this to test the wires to find the one's you're looking for.
...half of the truth can be worse than a lie. <----Roger Russell said that..
Posted: June 04, 2009 at 2:38 AM / IP Logged
Those acronyms were deliberately placed to test your knowledge, that fact that you didn't know what they were suggests you should have this installed professionally.
msmart
Posted: June 04, 2009 at 10:02 AM / IP Logged
I wont be installing it alone, my mate's an electrician. Lucky me!!
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
