6.5 tang band subs
spmpdr
Copper - Posts: 456
Posted: June 05, 2009 at 9:22 AM / IP Logged
I have a 2003 dodge ram reg cab with the following setup : mbquart 6.5 component set in the doors powered by a kenwood 500x4 (only using the hpf channels though) . 2 12" mbquart discus subs powered by a memphis class d 500watt rms.
my question: should I mount the tang bands in the rear near the other subs or in the front with the other mids like in the kick panels. IF I put them in the rear I was going to make tubes for them for better bass , if I put them in the front I was going to make kick panel enclosure but would not be able to get exact amount of cu.ft. on specs. I am looking for the best location for sound qaulity not spl thanks in advance.
-A vision without a plan is just a hallucination-
DYohn
Platinum - Posts: 10,741
Posted: June 05, 2009 at 9:51 AM / IP Logged
What are you planning to use them for?  You already have a good set of 12" subwoofers...
spmpdr
Copper - Posts: 456
Posted: June 05, 2009 at 2:04 PM / IP Logged
 I was planning to use them more for bass than for highs if that makes sense
DYohn
Posted: June 05, 2009 at 5:00 PM / IP Logged
spmpdr wrote:
sorry for the second thread but I dint think i expained it right. anyway I was planning to use them more for bass than for highs if that makes sense
You don't need them.  You have 12" subs and 6.5" mains.  Set the HP crossover for the mains and the LP crossover for the subs at the same point around 80Hz and you should be fine.
spmpdr
Copper - Posts: 456
Posted: June 05, 2009 at 9:04 PM / IP Logged
thanks for the info my set up sounds alot cleaner at 80hz, know anyone who wants some tang bands? lol j/k. any chance you might know whatthe svc feature on an eclipse cd3200 hu might mean. it sure makes my front stage louder, I looked in the owner manual but it doesnt say. thanks again
DYohn
Posted: June 05, 2009 at 10:57 PM / IP Logged
SVC is "source volume control."  It allows you to set a different default level for each input.  See your owner's manual for instructions on how to set it.
spmpdr
Copper - Posts: 456
Posted: June 06, 2009 at 9:42 AM / IP Logged
thanks again my friend, you guys are like modern day yodas at this!!!!
