how do i wire these components
chevy sounds
Member - Posts: 15
Posted: June 08, 2009 at 11:22 PM / IP Logged
I got a new set of components and on the crossover they have an input for the mids and an input for the tweaters my stereo doesnt have enough channels and I dont know if an amp would blow the tweaters... So how should I wire these up? Would it be okay to link the + input on the mid to the +  on the tweater and negative on - on mid to - on tweater input???
haemphyst
Platinum - Posts: 5,059
Posted: June 08, 2009 at 11:25 PM / IP Logged
Yes. In fact, the crossovers SHOULD have come with a jumper, to do just that.
They are a bi-wirable component set, and if you were to wire an amp channel to each input, you would still be golden. Just make certaiun that the amplifier power does not exceed the power specified by the manufacturer, and you'll be fine.
chevy sounds
Member - Posts: 15
Posted: June 09, 2009 at 12:09 AM / IP Logged
All right thanks for the help
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
