what do you think of this set up?
soundnsecurity
Gold - Posts: 2,711
Posted: June 21, 2009 at 8:13 PM / IP Logged
nissan370z
Member - Posts: 39
Posted: June 21, 2009 at 8:17 PM / IP Logged
you think it would be crazy expensive? so to get the most out of my system what do you think i would need to hold a amp that is powered at 2000-2500 rms. a 200amp alternator and another battery?
soundnsecurity
Gold - Posts: 2,711
Posted: June 21, 2009 at 9:50 PM / IP Logged
if you want it to look good then yeah i think it would be pretty expensive. but, if you just wanted to take the back seat out and have the box fire through the hole then that wouldn't be too bad.
a true 2000W amp will need about 120 amps worth of current so a 200 amp alternator would be the best thing for you to get along with a 0 gauge amp kit and an upgrade to your factory wires under the hood that supply the alternator and battery as well as a thick ground from the battery to the chassis. if you have a good battery already then you might not need another one, that would be the last thing i would get.
nissan370z
Member - Posts: 39
Posted: June 22, 2009 at 5:16 AM / IP Logged
yea thats what i want to hear.. lol thats more then likely what ill do.. change out the battery cuz the stock is very good.. and put a 2nd battery in the trunk and a aftermarket alternator.. it will be great
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
