bypass passenger switch
manassasralph
Posted: June 25, 2009 at 10:08 PM / IP Logged
I am installing universal power window kit. Instead of putting two switches in the drivers door and one in the passengers, I want to install the two drivers side switches in the center console and bypass the passenger switch.
Passenger switch receptacle has (position 1)pink + (position 5)yellow wire coming from power window motor; (position 3)white (center position in receptacle); (position 2) blue; (position 4) purple.
I'm lost, how can I eliminate the switch?
Any help is appreciated.
tommy...
Gold - Posts: 1,901
Posted: June 25, 2009 at 10:34 PM / IP Logged
If you could list the Part # of window kit w/ the year , make , model of the car...Im sure it will help specific questions/answers...!
M.E.C.P & First-Class
manassasralph
Posted: June 26, 2009 at 10:48 AM / IP Logged
Universal Power Windows with 3 switches (2 window kit) is a PROW-200 by Protocol.
Vehicle is 94 Ford Ranger reg cab with manual windows.
Posted: June 26, 2009 at 4:44 PM / IP Logged
Just wire both windows as the driver's switch, ie power to centre  terminal, next two out are the grounds, outers are up and down motor wires.
