03 jeep liberty bypass problems
sweetcoupe
Member - Posts: 24
Posted: June 28, 2009 at 12:48 PM / IP Logged
I see what you mean. That could cause my problem right? unfortunately i wont be able to get at the car till wednesday but ill let you know how it goes!
tommy...
Gold - Posts: 1,901
Posted: June 28, 2009 at 6:27 PM / IP Logged
Dont mind the circles...For another post...!
03 jeep liberty bypass problems - Page 2 -- posted image.
Here is the Pinout information for the 22 Pin Connector (Pin 21)
M.E.C.P & First-Class
sweetcoupe
Member - Posts: 24
Posted: June 29, 2009 at 6:39 AM / IP Logged
so ultimately im tapping into the vehicle speed sense supply line right?
Sounds wierd
tommy...
Gold - Posts: 1,901
Posted: June 29, 2009 at 9:43 AM / IP Logged
Did you download latest instructions/install guide after you flashed...! If you have another unit...Flash it and then print out manual...Might help...
sweetcoupe
Member - Posts: 24
Posted: June 29, 2009 at 12:41 PM / IP Logged
Is it necessary to flash it? I dont have the adapter or whatever to hook it to the computer. I just assumed that was if you wanted to update firmware and it wasnt necessarily needed to work
tommy...
Gold - Posts: 1,901
Posted: June 29, 2009 at 7:54 PM / IP Logged
its ok if the default firmware is what you needed...The firmware is vehicle specific...
tommy...
Gold - Posts: 1,901
Posted: June 30, 2009 at 1:31 AM / IP Logged
http://documents.audiovox.com/700690.pdf ...Another BCM pinout
sweetcoupe
Member - Posts: 24
Posted: June 30, 2009 at 9:24 AM / IP Logged
Ok now im confused again. So the pink/purple wire is going to be in the C2 area? or on the bottom of the BCM connectors. I thought it was a pin in the Bottom BCM connector i was tieing into.
I also see what i tied into which was the factory disarm light GREEN/ orange wire.
sweetcoupe
Member - Posts: 24
Posted: June 30, 2009 at 12:07 PM / IP Logged
Ok i just reread all the posts and i should be looking at the C2 plug right where the diagram shows it. Ill take a look at see. I got the BCM plugs and the C!,2,and 3 connectors all confused. Im rolling again lol
sweetcoupe
Member - Posts: 24
Posted: August 05, 2009 at 1:03 PM / IP Logged
Thanks for all your help. I know its been a while but i finally got back to working on the jeep and once i flashed the module to the right firmware and moved the violet/white to the pink/purple in the diagram you showed me everything worked perfectly!!!
Page of 3
