06 f 150 wiring diagram
ej2454
Posted: June 28, 2009 at 10:29 AM / IP Logged
trying to install amp and subs got everything ready to go but I have OEM 6 disc/mp3 radio and I noticed it has no RCA cable hookups what do I do???Any help would be great also easiest way to hook into the ignition for amp turn on
Platinum - Posts: 13,726
Posted: June 28, 2009 at 10:59 AM / IP Logged
Go to your local stereo shop and purchase a Line Out Converter.  Let me know when you get back.  It will cost you around 20 dollars for the LOC.
06 f 150 wiring diagram -- posted image.BatteryLIGHT GREEN/ VIOLET(+)RADIO HARNESS
06 f 150 wiring diagram -- posted image.AccesoryLIGHT GREEN/ YELLOW(+)RADIO HARNESS06 f 150 wiring diagram -- posted image.
06 f 150 wiring diagram -- posted image.GroundBLACK(-)RADIO HARNESS
06 f 150 wiring diagram -- posted image.IlluminationLIGHT BLUE/RED(+)RADIO HARNESS
06 f 150 wiring diagram -- posted image.LF Speaker (+)ORANGE / LIGHT GREEN
06 f 150 wiring diagram -- posted image.LF Speaker (-)LIGHT BLUE/WHITE
06 f 150 wiring diagram -- posted image.RF Speaker (+)WHITE/ LIGHT GREEN
06 f 150 wiring diagram -- posted image.RF Speaker (-)DARK GREEN/ ORANGE
06 f 150 wiring diagram -- posted image.LR Speaker (+)GRAY/LIGHT BLUE
06 f 150 wiring diagram -- posted image.LR Speaker (-)TAN / YELLOW
06 f 150 wiring diagram -- posted image.RR Speaker (+)ORANGE / RED
06 f 150 wiring diagram -- posted image.RR Speaker (-)BROWN / PINK
The Line out converter connects to the rear speaker wires at the back of the radio.   You can connect the remote wire to the accessory wire of the radio.
tommy...
Gold - Posts: 1,901
Posted: June 28, 2009 at 11:32 AM / IP Logged
What about the high input on most amps these days...? Think this has one...? Is the LOC better because of mounting location...What can these inputs usually handle...?(high inputs on amp)...(and sorry for squeezing in on your post...!)
M.E.C.P & First-Class
Posted: June 28, 2009 at 12:24 PM / IP Logged
With the cost of newer output chips in any radio, but especially OEM radios, I really don't encourage running speaker wires through a vehicle and have that much more of a chance of running a screw or having a door sill clamp penetrate the wire and take the radio out.  The diminished chance of taking a deck out is really worth the 20 dollar investment of the LOC.   If you can even find a repair facility near you.
ej2454
Posted: June 28, 2009 at 6:05 PM / IP Logged
Thank You so much....Followed your lead and everything works great I appreciate it....
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
