running accessories with multiple relays
69charged
Member - Posts: 10
Posted: July 09, 2009 at 8:18 PM / IP Logged
hello all. i have installed 4 relays in my truck. one is for my headrest screens, one is for my sat radio, and the other is to turn on my amps, and the fourth one is from the accessory wire off my head unit to turn on the other 3 relays. needless to say, there is a little wiring mess i am having to contend with. i labeled everything so its not too bad. now, my question. i know that i saw a site where you can get accessory  controller boards but now i cant find them. i would like one that is all in one unit (prefferably with a circuit board) so as to clean things up and have a better install. if anyone knows of anything out there that is electronically controlled, like with a microprocessor or something, that would be even better.
thanks
clarence
KPierson
Platinum - Posts: 3,527
Posted: July 09, 2009 at 9:23 PM / IP Logged
What exactly would this microprocessor be microprocessing?
You may be better off looking for a 4PST, a 4PDT, a 3PST, or a 3PDT relay.  It sounds like you only need one coil (since all coils are controlled by the same source - your turn on wire) and a NO set of contacts.
By eliminating the extra 3 coils you will eliminate 6 wires.  By going from DT to ST you'll eliminate another 4 wires.  You could then jumper all the common contacts together and have very little wiring in the end.
Kevin Pierson
69charged
Member - Posts: 10
Posted: July 09, 2009 at 10:05 PM / IP Logged
i guess a microprocessor was not the word i was looking for. my bad! i just want it all cleaned up so that its not a rats nest. i should have done it right the first time but......thanks for the reply i will try to let what you said absorb to my brain.
clarence
t&t tech
Platinum - Posts: 2,622
Posted: July 11, 2009 at 5:54 AM / IP Logged
i'm just thinking out loud here, i think this is what kevin is try in to say to, won't one relay be capable of doing all the work that the four relays are currently doing, mr69 charged, the NO contacts of a relay are capable of up to 40 amps of current, this should more than be sufficient to supply the accessories you mentioned above, just be sure to have a proper fused power source!
