how to shorten negative pulse to horn?
hang122660
Posted: July 26, 2009 at 8:05 PM / IP Logged
I have hooked the negative door lock and unlock wires of my alarm to the negative wire from the horn button. I would like to shorten this pulse to about 1/2 second from about 2 seconds.  Two seconds is to long to honk the horn.
And should I add any diodes to this setup?
hang122660
Posted: July 26, 2009 at 8:17 PM / IP Logged
Forgot to add.
I do not have power door locks. The door lock/unlock pulse is only being used to sound the car horn.
yimke
Copper - Posts: 417
Posted: July 26, 2009 at 8:22 PM / IP Logged
Don't you have a horn output wire?
KarTuneMan
Platinum - Posts: 7,056
Posted: July 26, 2009 at 9:12 PM / IP Logged
PLEASE..... try one more time?
hang122660
Posted: July 27, 2009 at 1:40 PM / IP Logged
No, that is why I have it hooked up this way. The alarm system I got is what I guess you would call a passive system.
It is a Bulldog KE150 I got at Goodwill for $10.00.
Chris Luongo
Platinum - Posts: 3,746
Posted: July 28, 2009 at 9:21 AM / IP Logged
I've never used one before, but search for the PAC TR-7.
It's a little timer module with all kinds of cool inputs and outputs and timing adjustments......but I'm not sure if it has a timing selection short enough for your needs.
Just to give you an idea, the Audiovox remote starters I use have a selection for the horn timing, and I think the options are:
10ms, 16ms, 30ms, 40ms, 50ms.
The 16 (default) makes the same kind of honking like most factory keyless systems. The 10 is so quiet you can't hear it very well on a busy street. The 50 isn't objectionable, but is a little too loud for my tastes.
So at least there you have some idea of what kind of timing you need.
OmarR
Copper - Posts: 162
Posted: July 28, 2009 at 8:21 PM / IP Logged
Along with Chris' suggestion, another popular one is the DEI 528t.
The input can be a neg or positive pulse, and the output can be anywhere between 1-90 seconds. In reality, if you turn the potentiometer all the way to it's lowest setting, i think you can output like .5 seconds.
They usually average $15 on ebay.
