2002 mustang gt kill switch
mustangkid92
Posted: August 15, 2009 at 9:25 PM / IP Logged
hey all i been trying to install a kill switch ignition in my 02 gt b.c my neighborhood is pretty bad.. but i been stuck so some help would be appreciated.. fyi.. i been searching for 2 weeks around and none of the threads from other forums are clear enough or on different car models so i thought i start my own for personal help
i ordered this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJ776&P=FR to start out..
so here is what i know so far, correct me if im wrong: start from the ignition by taking apart it then finding the correct wire, ( use service manual to find right wire) so cut the 1 or 2 correct wire then use what i bought to fill in the cut i made? Then bring in a cord to extend it? Im sort of lost, help would be appreciated.. sort of what to do this on my own!
mikvot
Gold - Posts: 1,043
Posted: August 15, 2009 at 9:55 PM / IP Logged
I don't see the point. The car already has a factory immobilizer on it. if a thief can figure out how to get past that, they will definately get past your little switch. If you really want to protect your car, install an alarm.
KPierson
Platinum - Posts: 3,527
Posted: August 16, 2009 at 8:01 AM / IP Logged
That wire looks awfully small, you probably won't be able to safely wire an ignition lead direclty through it, you will probably need a relay.  If the relay isn't installed properly (or if you forget to turn it "on") it will drain your battery.  This really isn't a good solutiion - try to find a bigger switch (at least 15A).
Kevin Pierson
