dodge truck problem
mytloud1
Member - Posts: 25
Posted: March 28, 2003 at 3:19 PM / IP Logged
had a guy bring me a 2002 dodge pickup. he bought a premade mtx box and a small mtx amp at the local electronics store. he wanted to keep his stock cd player. the truck has an infinity system in it. i am not familiar with dodge, so we ran into a few problems. the amp he bought had speaker wire type inputs, so i thought this would be easy. but i tied into the rear speakers, and when i turned everything on, the subs just thump, and no matter what the gain ajustment is they do the same thing. cannot seem to find an another amp for the infinity system, so i am lost now. tried using a line level converter both passive and electronic, no good. he is coming back to get his truck in a bit, so could you guys help me out a bit here. thanks in advance!!
esmith69
Gold - Posts: 1,511
Posted: March 28, 2003 at 3:45 PM / IP Logged
you mean like a turn-on thump and then no music?
mytloud1
Member - Posts: 25
Posted: March 28, 2003 at 3:50 PM / IP Logged
it kind of resembles music, but it isnt the right beat. i dont know if the rear speakers i tapped into are x'd over or what the heck is going on.
esmith69
Gold - Posts: 1,511
Posted: March 28, 2003 at 4:02 PM / IP Logged
mytloud1
Member - Posts: 25
Posted: March 28, 2003 at 5:33 PM / IP Logged
this doesnt seem to help me, there are only two wires going to each speaker in the rear of this truck. it is a regular cab model. any other suggestions, besides buying a new head unit, or is this the only option left?
mytloud1
Member - Posts: 25
Posted: March 29, 2003 at 11:51 AM / IP Logged
anybody? any ideas?
esmith69
Gold - Posts: 1,511
Posted: March 29, 2003 at 7:00 PM / IP Logged
First of all I'd recommend using an external line out converter as these usually performa better than the ones built in to amps.   Even if it didn't make a difference before you should still use it when possible.
Have you tried hooking up a test input to the amp to see if the problem still happens?  And what about using a test amp with the factory speaker wires?
If you can do those two tests you can eliminate a bunch of stuff as possible causes.  The reason I suggest this is because you said you get bass, so that can't mean you've tapped in to a high-frequency-only speaker wire.  Although if that were the case the solution would be to tap in to the wires going to the 6x9s in the doors as they are sure to get the most bass out of all the speakers in the system.
Of course I'll say the same old BS---check your ground, power, and signal connections, and check the sub wires for polarity and proper connection,bla bla bla...
First thing I'd do is get a walkman or a test head unit and hook it up to the amp, and then see what the bass sounds like.
mytloud1
Member - Posts: 25
Posted: March 30, 2003 at 9:01 AM / IP Logged
we ran rca's to another head unit, and it worked very nicely, but the factory head unit produces nothing but noise to the amp. when you turn it on, it just thumps continuously. it is not in the amp or subs though, been through that. it has some thing to do with this dang dodge/infinity stock crap.
esmith69
Gold - Posts: 1,511
Posted: March 30, 2003 at 1:55 PM / IP Logged
Okie I got another idea.  Instead of tapping in to the wires at the back speakers, or at any of the speakers for that matter, just tap in to the wires in the radio's harness.  You might need an LOC or similar device to match up the signal level as I don't remember if it's a high or low level signal coming from the head unit.
The factory wiring goes as follows:
rear left positive: BROWN / yellow
rear left negative:Dark Blue/red
rear right positive: Dark Blue/white
rear right negative: Light Blue/orange
mytloud1
Member - Posts: 25
Posted: March 31, 2003 at 1:49 PM / IP Logged
we'll give it a try and let you know what happens. thanks alot!!!
