1999 pontiac montana remote start gmdaa
rmarcelle05
Posted: September 09, 2009 at 3:12 PM / IP Logged
I put in an UltraStart remote starter in a 1999 pontiac montana and I used a leftover gmdaa (data) for the pk3 bypass and now it starts and other times it doesn't. Is there a keysense wire that has to be hooked up? What wire would I hook up to that if that is needed?
Tantrum
kgerry
Platinum - Posts: 3,455
Posted: September 10, 2009 at 5:22 PM / IP Logged
when it doesn't start have you isolated whether it is a Transponder issue or a tach issue?    does the model require a keysense wire to be connected? most data solutions do not...
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
rmarcelle05
Posted: September 10, 2009 at 6:40 PM / IP Logged
it starts sometimes and dies the next and the passkey light flashes, it turns out other then being outdated (obsolete) the module was only designed for 2000+ montanas, hence the reason why it partly works, i guess. I chose to go with a 555g (dei) that should work
Tantrum
