ford truck turn signals
bob02748
Posted: October 03, 2009 at 12:33 PM / IP Logged
I have a 2003 Ford F-350. The flat-bed body has LED stop/turn/tails and traditional incandescent front turn signals. Because the rear LED's do not draw enough amperage, the Ford flasher "thinks" that I have a bad bulb, so the turn signals flash fast. To overcome this, I have a couple hidden lamps hidden under the body. There must be a better way.
Platinum - Posts: 13,667
Posted: October 03, 2009 at 9:41 PM / IP Logged
There are solid state flashers for some vehicles.  The only other way is the lamps you already have or a high power resistor.  The resistor will need to be mounted to the chassis to disipate the heat that it will put out.  Radio Shack sells an 8 ohm 20 watt resistor.
ckeeler
Gold - Posts: 1,461
Posted: October 05, 2009 at 2:58 PM / IP Logged
there is a much better way indeed. here
electronic LED flasher Grote part #44090
ford truck turn signals - Last Post -- posted image.
d_rock_81
Member - Posts: 39
Posted: October 05, 2009 at 4:13 PM / IP Logged
most after-market led taillight companies make a power resister for their taillights also.
Dustin Rockney
Rockstar Autosports
