ign2 wire which color?
sublime44
Member - Posts: 25
Posted: October 09, 2009 at 7:58 PM / IP Logged
This link here http://64.85.6.118/diagrams/diagrams.asp states that my 2000 gmc sonoma has an ign 2 wire which is white but the link on this site states that it should be orange. Which should I follow?
sublime44
Member - Posts: 25
Posted: October 09, 2009 at 8:00 PM / IP Logged
Sorry here's a direct link
t&t tech
Platinum - Posts: 2,622
Posted: October 09, 2009 at 9:33 PM / IP Logged
Me again here, you should follow your meter and its's readings!
Platinum - Posts: 13,726
Posted: October 09, 2009 at 9:35 PM / IP Logged
What is a meter?  What are these readings you keep talking about?
http://64.85.6.121/diagrams/diagram.asp?ModelID=15370&MakeID=20&link=BULLDOG
Did you read note 4?
According to techservices.audiovox.com there are 3 Ignition wires.
ign2 wire which color? -- posted image.BatteryRED(+)IGNITION SWITCH HARNESS
ign2 wire which color? -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
ign2 wire which color? -- posted image.Ignition 2ORANGE(+)IGNITION SWITCH HARNESS
ign2 wire which color? -- posted image.Ignition 3WHITE(+)OR PNK/WHT IGN HARNESS (TRANSMISSION)
ign2 wire which color? -- posted image.Accessory 1BROWN(+)IGNITION SWITCH HARNESS
ign2 wire which color? -- posted image.Starter 1YELLOW(+)OR VIO IGN SWITCH HARNESS
ign2 wire which color? -- posted image.Anti-Theft TypeRESISTOR BASED SYS
ign2 wire which color? -- posted image.Anti-Theft DescriptPASSLOCK II
ign2 wire which color? -- posted image.Key SenseLIGHT GREEN(-)STEERING COLUMN HARNESS
ign2 wire which color? -- posted image.Neutral SafetyNOT GRDING
ign2 wire which color? -- posted image.TachometerWHITE(-)COIL TOP OF ENG PASS SIDE
ign2 wire which color? -- posted image.Speed SenseGREEN / WHITE(AC)PASS FRT QTR BLK 80 PIN CONN POS 16
ign2 wire which color? -- posted image.Parking LightsBROWN(+)AT LIGHT SWITCH OR LTBLU PLUG AT BCM
ign2 wire which color? -- posted image.Brake LightsLIGHT BLUE(+)BRAKE SWITCH ABOVE BRAKE PEDAL OR WHT
ign2 wire which color? -- posted image.Reverse LightsLIGHT GREEN(+)NEUTRAL SAFTEY SWITCH
ign2 wire which color? -- posted image.HornBLACK(-)BRN PLUG AT BCM
t&t tech
Posted: October 09, 2009 at 9:54 PM / IP Logged
It's a superbly crafted tool, that can actually read voltage, i'm so glad to have found it, you really should get one mr.idiot! LOLign2 wire which color? -- posted image.
t&t tech
Posted: October 09, 2009 at 9:56 PM / IP Logged
It also give you the ability to connect wires without a doubt in you mind!
sublime44
Member - Posts: 25
Posted: October 09, 2009 at 9:57 PM / IP Logged
So which diagram do iI follow in regards to ing 1 and 2? or 3??
t&t tech
Posted: October 09, 2009 at 10:00 PM / IP Logged
Connect all ignitoin wires at the harness, but that white one must be used as an ignition 2 to enable remote starting!
sublime44
Member - Posts: 25
Posted: October 10, 2009 at 9:01 AM / IP Logged
Would you know what readings I should be getting on the white wire?
KarTuneMan
Platinum - Posts: 7,056
Posted: October 10, 2009 at 10:38 AM / IP Logged
Ignition (+) Input
Connect to a source that has (+)12 V DC only when the ignition key is in the run and start positions. See your installation manual for more info.
