push button start, 2007 vw jetta?
mitch0627
Posted: October 09, 2009 at 5:39 PM / IP Logged
Hello Guys:
I decided to install a NIKEN, push Start button, unfortunately the instructions don't tell me much, I was wondering if you could indicate me how to do so myself? The instructions only say:
1 Connect the push button to the relay. (Done)
2 The Black wire to ground (Done)
3 THE GREEN WIRE SHOULD BE CONNECTED TO TERMINAL 15(IGN)BEHIND THE IGNITION 4 SWITCH, WITH ANOTHER ONCE CONNECTING TERMINAL 50, BEHIND THE IGNITION SWITCH AS WELL
5 THE RED WIRE SHOULD BE CONNECTED TO TERMINAL 15
These are all the steps, as you can see, I only done 2, the other steps I am not so sure. Could you please tell me what to do exactly on a 2007 vw jatta
thanks
t&t tech
Platinum - Posts: 2,622
Posted: October 09, 2009 at 6:13 PM / IP Logged
OH DEAR! push button start, 2007 vw jetta? -- posted image.
mitch0627
Posted: October 10, 2009 at 6:28 PM / IP Logged
im looking for the ignition diagram (colors and all ) for a 2007 vw jetta
thanks
Platinum - Posts: 13,725
mitch0627
Posted: October 10, 2009 at 8:41 PM / IP Logged
IGNITION      Yellow      On back of ignition switch       +
          Remove the plastic cover around the steering column and you will see a small black box mounted to column held by 1 torx screw. Remove this box to expose the ignition key wires, they are all 22 gauge.
ACCESSORY      Green      On back of ignition switch       +
STARTER      Red      On back of ignition switch       +
          Remove the plastic cover around the steering column and you will see a small black box mounted to column held by 1 torx screw. Remove this box to expose the ignition key wires, they are all 22 gauge.IGNITION Yellow On back of ignition switch + Remove the plastic cover around the steering column and you will see a small black box mounted to column held by 1 torx screw. Remove this box to expose the ignition key wires, they are all 22 gauge. ACCESSORY Green On back of ignition switch + Remove the plastic cover around the steering column and you will see a small black box mounted to column held by 1 torx screw. Remove this box to expose the ignition key wires, they are all 22 gauge. STARTER Red On back of ignition switch + Remove the plastic cover around the steering column and you will see a small black box mounted to column held by 1 torx screw. Remove this box to expose the ignition key wires, they are all 22 gauge.
is there any way i can get to them wires with out taking the torx screw ???
Platinum - Posts: 12,488
Posted: October 10, 2009 at 10:31 PM / IP Logged
You DO NOT need to remove the box on these VW's. You can access the wires at the base of the box by cutting into the taped loom of wires. Use a CANSL2 or the iDatalink AL-CA and this will give you all the convenience feature interface wires necessary for alarm & remote start connections.
mitch0627
Posted: October 11, 2009 at 8:53 AM / IP Logged
I'm trying to put a engine start button .   Will this still work ??
Posted: October 11, 2009 at 9:24 AM / IP Logged
Yes, it will work. The wires are located after the black box under the steering wheel at the base.
Posted: October 11, 2009 at 9:28 AM / IP Logged
Wire color is RED / BLACK and the IGNITION is BLACK
Posted: October 11, 2009 at 1:49 PM / IP Logged
Relevant to t&t's comment. what's the problem with the torx screw?  If you don't have a t20 driver/bit don't even attempt to work on one of these.
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
