hifonics amp problems
Platinum - Posts: 13,726
Posted: October 17, 2009 at 4:01 PM / IP Logged
You can not check to see if your power wire is OK without having something trying to pull current through the wire.   No load = no current draw, no current draw = NO voltage drop.  You can connect a 100 ohm resistor in series with a wire and with no load on that wire, the voltage will still read what the voltage is at the battery.  (If using a digital volt meter)  So checking voltage on a wire that has no load on it, is useless.
madspeed
Member - Posts: 8
Posted: October 23, 2009 at 10:42 PM / IP Logged
You allmost have your own problem solved. You said it yourself you had 8 volts and unhooked had normal voltage. You should Google Voltage drop testing and I am very confident you will figure it out fast. when you take the load of a circuit the resistance( or bad connection) wont matter you will read full voltage. Learn voltage drop tesing it will get you where you need to go
armymp90099
Copper - Posts: 76
Posted: October 27, 2009 at 5:17 PM / IP Logged
ok guys. well my other friend who was helping us is a little slow apparently... he was the one who checked the power cable on the battery and said it was good. i personally checked it and it slipped right out of the ring terminal. wow right? so i crimped a new one and everything works great. lol thanks for all your help guys.
-ETS-
Escape The Scilence
