how to uninstall factory alarm?
LudeBoi
Copper - Posts: 81
Posted: April 04, 2003 at 12:26 AM / IP Logged
the problem is that the OEM security goes off, so, i just want to disconnect it..i just hooked up the lock/unlock wires from the prestige to the kick panel like the diagram said...it locks, but doesn't unlock, this has happened before i even touched it, even with the factory alarm, is it wise to direct wire to the switch?
Platinum - Posts: 12,488
Posted: April 04, 2003 at 12:45 PM / IP Logged
Are you sure you grabbef the right UNLOCK wire ? Did the wire you tapped into test (-) when you toggle the PASSENGER side controls ?
LudeBoi
Copper - Posts: 81
Posted: April 06, 2003 at 1:34 AM / IP Logged
how do i turn off the OEM security? because it arms itself...on the Prestige I used the green and red wires for lock and unlock
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
