07 ram 3500 6.7 dies, rem start
portugal-alvaro
Posted: October 28, 2009 at 12:12 PM / IP Logged
Installing a Zenesis 2 way alarm/starter combo with a fortin duo can 2 module kit.
was able to program interface module and all alarm functions are working. door lock. triggers etc. Connected the alarm using the doc 1084 found on this site but starter will not engage at all, all ignition functions work but the starter will not turn on. PLEASE HELP!!!
portugal-alvaro
syl20rochon
Copper - Posts: 298
Posted: October 29, 2009 at 6:05 PM / IP Logged
Can you describe how you've connected your bypass module, sounds like it is not connected properly or wrongly programmed, give a description of what you did with all the wires on the bypass.....I'll see if I can help
Sylvain Rochon
MECP security specialist
Tech support for remote starters
26 Years of experience counts
I'm here to help.
portugal-alvaro
Posted: October 30, 2009 at 3:59 PM / IP Logged
Thanks i'll open it up and post again
portugal-alvaro
Platinum - Posts: 12,488
Posted: October 30, 2009 at 4:11 PM / IP Logged
If the truck has a starter wire, you must hook up the YELLOW starter wire from the DUO-CAN to the vehicle starter wire as well as the starter output from the Zenesis system.
