hooking up boot solinoid to central lock
colin12
Member - Posts: 16
Posted: November 02, 2009 at 9:28 PM / IP Logged
Hey,
First time poster long time reader of these forums.
I installed a soliniod in my boot no problems at all but im having trouble hooking it up to my central locking the soliniod opens the boot when i tap the power cable to the battery. How do i hook it up to my central locking? my central locking has an output for the boot but that only out puts around 0.5volts which is not enough to activate the soliniod. Could someone please explain what i need to do.
The only advice i have found is use a relay if someone could please explain what i need to do with the relay it would be much appreciated thanks if you need more info please ask i would realy like to get this sorted out soon
tedmond
Gold - Posts: 4,610
Posted: November 02, 2009 at 9:55 PM / IP Logged
what type of solenoid are we talking about? door popper, actuator?
you first need to find out what type of polarity the solenoid is. most that i have seen are reverse polarity, but they all vary brand to brand. once you have found what trigger it requires, then can you start tapping into the door lock wires usually found in the door, dkp or up high in the knee kick. also dont forget to tell us what car or we cant give you diagrams/wire colour
colin12
Member - Posts: 16
Posted: November 02, 2009 at 10:00 PM / IP Logged
This is the soliniod i have http://www.dynatron.co.nz/item_universal-electric-boot-solenoid-kit_5739 its hooked up in the boot only two cables from the solinoid one is grounded in the boot the other one is the power one. it unlocks the boot when i tap the power cable to the battery. The central locking in my car is not stock. my car is a 1998 mitsibithi lancer gli
Platinum - Posts: 13,724
Posted: November 02, 2009 at 10:11 PM / IP Logged
I can only assume that your central locking system has a negative output that will only trigger a relay.  If this is true, the following should help you.  Connect that wire to terminal 85 of the relay.  Connect terminals 30 and 86 to the battery via a 10 amp fuse mounted at the battery.  The wire that you touch to the battery that makes the solenoid move, connect that wire to terminal 87.
hooking up boot solinoid to central lock -- posted image.
colin12
Member - Posts: 16
Posted: November 02, 2009 at 10:28 PM / IP Logged
Thanks for the reply, I am realy new at all of this my central locking has an out put for boot release that sends out 0.5 volts when i press the boot release button on my keys so where abouts would i hook that up on the relay and when i go to buy the relay do they come in diffrent sizes or anything else i need to know before buying one?
Posted: November 02, 2009 at 10:50 PM / IP Logged
I have never seen an alarm or keyless module that puts out 1/2 of a volt.  Using a digital volt meter, attach the red lead to a known good 12 volt source.  Now touch and hold the black lead to the wire that you say has 1/2 of a volt on it when the boot is to be activated.  Press and hold the button that would release the boot.  Notice the reading on the meter.    If the meter reads anything over 8 volts or so, follow the instructions in my earlier post.
colin12
Member - Posts: 16
Posted: November 02, 2009 at 11:43 PM / IP Logged
Thanks you are right i was measuring the voltage wrong :( where can i get a relay like the one in the picture? can i just go into my local electronics store what is the name of the relay that i need to ask for?
Thanks for your help man
Posted: November 03, 2009 at 1:28 AM / IP Logged
Standard "Bosche type" automotive relay, also place a 15 amp fuse in line to termnal 30
Posted: November 03, 2009 at 1:29 AM / IP Logged
Sorry, I didn't see that Mr. I had mentioned a fuse.
Posted: November 03, 2009 at 1:34 AM / IP Logged
Let's start again, I'm half asleep still! The type of relay you wanted is in the link you posted, look under accessories. N.B. I don't know the exchange rate of the NZ $ against the £ but those prices are extortionate.
