cap wiring
1nicemustang
Copper - Posts: 89
Posted: April 02, 2003 at 10:53 AM / IP Logged
hey there everyone----when wiring a cap do i want--
A: the 4 ga wire to go to the cap then D-Block then split to the amps.
or
B: the 4 ga wire to go to the D-Block then split to a cap and the amps
if i remember correctly its choice A:
dragonrage
Copper - Posts: 193
Posted: April 02, 2003 at 11:02 AM / IP Logged
A is usually the better choice
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
thepencil
Gold - Posts: 1,526
Posted: April 02, 2003 at 12:00 PM / IP Logged
Just keep the cap as close as possible to the amp. I have not notice any significant sound difference that was audible between your two choices.
Be careful whose advice you buy, but be patient with those who supply it.cap wiring -- posted image.
x6369x
Copper - Posts: 108
Posted: April 02, 2003 at 10:10 PM / IP Logged
A if your running multiple sub amps.
B if your running only 1 sub amp.
Friends Don't Let Friends Bump Stock.
esmith69
Gold - Posts: 1,511
Posted: April 02, 2003 at 10:12 PM / IP Logged
I'd go for choice A--it seems the most logical way in my opinion--power source before the splitting point.  lol and besides I don't really understand what you meant about "splitting it to a cap" so that ruled out choice B for mecap wiring -- posted image.
x6369x
Copper - Posts: 108
Posted: April 02, 2003 at 10:43 PM / IP Logged
If your using only 1 bass amp, I would go from the dist block to the cap, then to the bass amp. Wiring it this way will deliver all of the cap's energy to the bass amp. Highs amps don't really benefit from a cap, since a caps attempt to keep battery voltage constant during deep/long bass notes. Try to keep the distance from the cap to the amp to less than 18".
1nicemustang
Copper - Posts: 89
Posted: April 03, 2003 at 2:26 PM / IP Logged
ok well i meant taking the wire from the cap to the d block....then 4 outputs from the block to the components.
i usually wire it wire cap dblock then to the amps. i figure the power would be equal throughout the whole range of the system and all could benifit from it.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
