need assistance choosing a sub amp
ragsports
Copper - Posts: 192
Posted: November 16, 2009 at 9:31 AM / IP Logged
Yes less voltage will make less power.  For example a 40 amp draw at 14.4 volts will make 576 watts as long as the system is 100 percent efficient.   That same 40 amps at 13.8 will make 552 watts as long as the system is 100 percent efficient.
Garbage in EQUALS Garbage out...
sciullo779
Member - Posts: 12
Posted: November 16, 2009 at 9:55 AM / IP Logged
so theoretically i could use a amp rated for a higher wattrms then my subs?
subs rated at 600wrms@2ohm
opinions on these?
http://www.woofersetc.com/p6859/FD-6001--ARC-Audio-1-Channel-620-Watt-Amplifier.htm
http://www.woofersetc.com/p7766/RUB1700--Soundstream-Monoblock-700-Watt-RMS-Rubicon-Series-Subwoofer-Amplifier.htm
http://www.woofersetc.com/p7845/DSC15001D--MB-Quart-Monoblock-1500-Watt-Discus-Series-Class-D-Amplifier.htm
ragsports
Copper - Posts: 192
Posted: November 17, 2009 at 12:18 AM / IP Logged
I say yes to the ARC audio, the rest on that list are ok.
