wait to start light not on
cannate
Posted: November 13, 2009 at 2:35 PM / IP Logged
 I just installed a remote starter in my diesel 06 F-350. I used the resource disk from this site and I got to say it was a great tool. For the wait to start I used a timer on the unit itself. Now my problem. The light on the dash for the wait to start doesn't come on when auto started. Is this O.K? It seems like the glow plugs are working but I live in a cold climate and would like to be sure. Also in the info there was a note at the bottom NOT to use the wait to start light. Anyone installed these before and encountered this?  Is this normal? Thanks in advance for any help or thoughts on this.
t&t tech
Platinum - Posts: 2,621
Posted: November 13, 2009 at 4:18 PM / IP Logged
I'm not absolutely sure. but i think the wait to start is data controlled, hence the advice to not use the light, someone else will verify, also, the glowplug light should come on as your'e duplicating the effect of turning the keys, are you powering all ignition and accesory circuits?
beegbie
Copper - Posts: 341
Posted: November 13, 2009 at 5:01 PM / IP Logged
Did you power up the radio accessory circuit? I never figured out why but i'm pretty sure that the light won't come on if you don't.
cannate
Posted: November 13, 2009 at 11:03 PM / IP Logged
 I've got some leads on this little problem. I checked the glow plug module and it is indeed not working. Can anyone tell me what the DRK BLU/ Light green wire does? Its not hooked up right now. On the vehicle wiring section of this site there seems to be a little views. On the 05 installation it says this wire is only used on gas start. Got any ideas.
Platinum - Posts: 13,724
Posted: November 14, 2009 at 4:25 AM / IP Logged
wait to start light not on -- posted image.BatteryYELLOW , LIGHT GREEN/ VIOLET(+)AT IGNITION SWITCH
wait to start light not on -- posted image.Ignition 1RED / LIGHT GREEN(+)AT IGNITION SWITCH
wait to start light not on -- posted image.Ignition 2RED / BLACK(+)AT IGNITION SWITCH
wait to start light not on -- posted image.Accessory 1GREY / YELLOW(+)AT IGNITION SWITCH
wait to start light not on -- posted image.Accessory 2DARK BLUE/LIGHT BLUE(+)IGNITION SWITCH HARNESS
wait to start light not on -- posted image.Starter 1DARK GREEN(+)AT IGNITION SWITCH
wait to start light not on -- posted image.Anti-Theft TypeNONE
wait to start light not on -- posted image.Key SenseBLACK/ PINK(-)IGNITION SWITCH HARNESS
wait to start light not on -- posted image.Neutral SafetyRED / LIGHT BLUE(+)IGNITION SWITCH HARNESS
wait to start light not on -- posted image.TachometerLIGHT GREEN / WHITE(AC)AT PCM PIN 25 OUT OF 50 PIN(GAS). PIN 1 OUT OF 46 PIN(DIESEL) AT PCM
wait to start light not on -- posted image.Speed SenseGRAY/BLACK(AC)PIN 29 OUT 50(GAS) PIN 35 OUT 46(DIESEL). 8000 PULSESwait to start light not on -- posted image.
wait to start light not on -- posted image.Parking LightsBROWN(+)AT HEADLIGHT SWITCH
wait to start light not on -- posted image.Brake LightsLIGHT GREEN(+)AT BRAKE SWITCH
wait to start light not on -- posted image.Reverse LightsBLACK/ PINK(+)AT LIGHT
wait to start light not on -- posted image.HornDARK BLUE(-)STEERING COLUMN
cannate
Posted: November 14, 2009 at 8:08 AM / IP Logged
Thanks! Your the first post to mention the drk blu/light blu I was wondering what that did. I'll give it a try as soon as I get a relay. Out of outputs.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
