python 1601 mustang
godshandkiller
Member - Posts: 15
Posted: November 28, 2009 at 6:04 PM / IP Logged
im installing a python 1601 in my 2000 mustang gt i have the alarm and the door locks and trunk pop working fine but the wiring for the remote start is confusing me this is the wiring for my car
Constant 12V+Yellow or Light GREEN/ Purple Ignition Switch Harness
StarterWHITE/ Pink Ignition Switch Harness
IgnitionRED / Light Green Ignition Switch Harness
Ignition 2Gray / YELLOW Ignition Switch Harness
AccessoryGray / YELLOW Ignition Switch Harness
and the wires on remote start harness,pink-ignition 1 (+)output,RED / white-fused 30a,orange accessory output,violet starter output,green starter input,red 12v constant fused 30 a input,pink/white flex relay output,pink/black flex relay contact 87a,RED / black fused 30a (for starter and accessory relays).any help would be appreciated
t&t tech
Platinum - Posts: 2,622
Posted: November 28, 2009 at 6:12 PM / IP Logged
RED / white, RED / black, and red all fuse at thirty amps connect to the ignition harness twelve volts constant,
Cut your WHITE/ pink starter wire in half, Green to the side from the keyswitch purple to the other side,
RED / light green connects to the pink wire from your relay,
gray / YELLOW, ignition two, to the pink/white
gray / YELLOW, accesory, to the orange wire,
isolate the pink/back not neccesary in this application!
