viper 5301, 2005 f150, no parking lights
madmaxed
Posted: November 30, 2009 at 11:49 AM / IP Logged
I installed a new Viper 5301 on my 2005 F150 this weekend. First time and things went rather well. Locks all work, remote start works. However, I don't get any parking light feedback. Parking lights work fine from the switch. Just no parking lights when remote started. I have the white wire (H1/11) to the brown wire (pin 6) at the BCM. Looking through the docs I see there is a setting in the viper unit for + vs - light. Just wondering what default is. I already have everything back together and want to see if this is most likely my problem.
One other note, it has automatic headlights. Not sure if that makes a difference or not.
Thanks,
jon
yimke
Copper - Posts: 417
Posted: November 30, 2009 at 6:53 PM / IP Logged
Isolate the wire by using the white to light side and WHITE/ brown to switch side. And remember to put your fuse in on the positive side inside the Viper unit.
robertsc
Copper - Posts: 337
Posted: November 30, 2009 at 7:00 PM / IP Logged
I would say put the fuse in 2 .
phorsfi
Member - Posts: 10
Posted: November 30, 2009 at 7:45 PM / IP Logged
yep, open the hatrch on the unit and install the 10A fuse that came with your unit in either the + or - jumper position. I only know because I just had said problem ;)
Pat
another-kelly
Silver - Posts: 618
Posted: December 01, 2009 at 1:22 AM / IP Logged
again, the fuse in the 5301. the "default" setting is off as they don't put the +/- selectable light flash fuse in there so you have to make the choice
madmaxed
Posted: December 01, 2009 at 6:24 AM / IP Logged
Thanks for all the responses. Stupid rookie mistake on my part. First system install. Didn't realize the fuse wasn't installed at all. Then had things all tied up before I noticed parking lights weren't on.
