wrapping a box with vinyl
pcana11
Copper - Posts: 116
Posted: November 30, 2009 at 9:53 PM / IP Logged
i have my box built sub in and tested and everything and i absolutely love it. i was wondering about wrapping it. i have built and wrapped boxes before with vinyl, but the sides never turned out great and i was wondering if anybody new any tips or techniques, thanks, patrick
squires500
Member - Posts: 47
Posted: December 06, 2009 at 4:08 AM / IP Logged
have you been using a heat gun?
pcana11
Copper - Posts: 116
Posted: December 06, 2009 at 10:13 AM / IP Logged
no, i do not own one
Platinum - Posts: 13,725
Posted: December 06, 2009 at 10:39 AM / IP Logged
Try setting the endcaps in about 3/8 of an inch.  Then cut an endcap out of 1/4 inch stock.  Cover it and set it into place.
pcana11
Copper - Posts: 116
Posted: December 06, 2009 at 10:56 AM / IP Logged
the box has already been built. i was thinking about, since i have some left over mdf, cutting the pieces to extend out 3/4" past the sides so i could wrap the new pieces, tuck them up under the ends and then put the end caps in
boogeyman
Silver - Posts: 359
Posted: December 07, 2009 at 8:09 AM / IP Logged
Your above suggestion pcana 11....was going to be my suggestion.
pcana11
Copper - Posts: 116
Posted: December 07, 2009 at 8:25 PM / IP Logged
i think that would be the best bet too. im gonna try that and see how it works
bellsracer
Silver - Posts: 703
Posted: January 10, 2010 at 2:42 PM / IP Logged
If you haven't already done this project yet, make sure you buy the 4way stretch vinyl for getting around the corners, it's more exspensive but a LOT easier to get around corners without the "elephant skin" forming.
Ganbatte ne!
boogeyman
Silver - Posts: 359
Posted: January 10, 2010 at 2:52 PM / IP Logged
in addition to the above post.....If you are not using the 4 way stretch vinyl, roundover the edges 1/2 roundover bit with a router or any other means to avoid "elephant skin"
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
