civic radio no lights
cpgoose
Gold - Posts: 1,098
Posted: December 02, 2009 at 12:15 PM / IP Logged
Howdy -
I have an old 1997 Civic with the stock radio still installed. The lights that light up the buttons went out unfortunately. I checked all of the fuses under the dash and under the hood and they're all fine.
So...I took the radio out and took it apart hoping to see a bulb. All I could see were about 5 LEDs soldered into the face's circuit board. Arg.
Does anyone have any ideas? I think it's strange that they all stopped working. They were working on and off for a few months and finally died.
I'm sure this is a lost cause, but thanks for any ideas.
Platinum - Posts: 13,725
Posted: December 02, 2009 at 3:05 PM / IP Logged
THey could all be wired in series.  A bad solder joint or 1 failed LED could cause all of them to go out.   Have you tried to remove the curcuit board to check for bad solder joints?
cpgoose
Gold - Posts: 1,098
Posted: December 02, 2009 at 3:47 PM / IP Logged
Well, there's a circuit board behind the faceplate and one that's part of the whole radio. I only checked where the LEDs are on the faceplate, but I'll give the other board another check.
Posted: December 02, 2009 at 4:23 PM / IP Logged
The board that contains the LEDs.
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
