95 mercury villager remote start
pavlik
Member - Posts: 11
Posted: December 09, 2009 at 3:00 PM / IP Logged
Hello everyone,
I tried to install a remote starter (Prestige) to my Mercury Villager 1995. I have a problem with finding where to connect  wire Tach and door lock and unlock. Please help me.
God bless You!
ckeeler
Gold - Posts: 1,461
Posted: December 09, 2009 at 4:26 PM / IP Logged
do you own a DMM or can you borrow one from a friend? it is a must to properly identify the correct wires.
pavlik
Member - Posts: 11
Posted: December 09, 2009 at 4:48 PM / IP Logged
I am sorry, but what is a DMM?
God bless You!
ckeeler
Gold - Posts: 1,461
Posted: December 09, 2009 at 4:56 PM / IP Logged
Digital Multi Meter. its also sometimes called a Digital Volt Meter.
pavlik
Member - Posts: 11
Posted: December 09, 2009 at 5:21 PM / IP Logged
I do have DMM, but how does it help me find the wires that i need to connect lock and unlock?
God bless You!
ckeeler
Gold - Posts: 1,461
Posted: December 09, 2009 at 5:30 PM / IP Logged
you use it to test the wires while operating the switch so that you know you have the correct wires before you just go and hook into them.
pavlik
Member - Posts: 11
Posted: December 09, 2009 at 5:39 PM / IP Logged
so do I need to pull the wires from remote starter to the door switch?
God bless You!
ckeeler
Gold - Posts: 1,461
Posted: December 09, 2009 at 5:56 PM / IP Logged
no. look for a GREEN / WHITE and GREEN/ orange wire in the drivers kick panel and then use your DMM to test them to be sure they are the correct wires. if not, keep looking for those colors and keep testing each time until you find them. dont attempt hooking up the door lock outputs from the R/S to any wires you find until you are positive through testing, that you found the correct wires. they are negative trigger.
pavlik
Member - Posts: 11
Posted: December 09, 2009 at 6:15 PM / IP Logged
Thanks, I tried to find them there but there are hundreds of wires and i dont know exactly were to find the wires that lock and unlock. Maybe you can tell me exactly were they are. or give me a link to an image. Wire to tach, do i need to attatch it to to the coil on the engine or can i find another wire under the kick panel
God bless You!
ckeeler
Gold - Posts: 1,461
Posted: December 09, 2009 at 7:10 PM / IP Logged
you may have better luck finding the wires in the kick panel for the locks if you can find the harness from the boor boot coming in, maybe you can even find them in the door boot itself. at any rate you dont need to remove the door panel or anything like that. i would use an injector wire for the tach signal if you are able to get one. all the injectors will have 2 colors with one color being common on them all, use any wire on any injector that is NOT the common color.
Sunday, July 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
