06 300 park light 2.4k or 1.67k?
todds440
Member - Posts: 48
Posted: December 17, 2009 at 7:21 AM / IP Logged
Doing a remote starter on 06 Chrysler 300.  I have 2 different wiring guides and they both have different values for the parking lights.  Which one is correct 2.4k or 1.67k?  Anyone who has done this vehicle please let me know.  If not Ill figure it out when I do install.  Thanks
subieken
Member - Posts: 18
Posted: December 17, 2009 at 5:22 PM / IP Logged
Get an iDatalink module and it will give you everything from the canbus. Check on their site for a vehicle specific application. If use the MULTI AL-CA boxes you'll probably have to go to a dealer to get it flashed but is saves so much headache.
Ken
JayDee AgTech
Swift Current, SK
djfearny2
Silver - Posts: 810
Posted: December 17, 2009 at 7:01 PM / IP Logged
dont barther with either as you will also have to wire up a relay to seperate the wire from the switch or your fog lights will flash as well.
instead you can get possitive wire in the passangter kick pannel. I am pretty sure it is white purple. to verify color look at the tail light wire harness. right side. easiest thing to do.
Jon
Installer/Help Technician
---coral springs florida---
metz35
Copper - Posts: 458
Posted: December 17, 2009 at 8:17 PM / IP Logged
white purple + like djfearny2 says..
but to answer your question 1.6
subieken
Member - Posts: 18
Posted: December 18, 2009 at 8:45 AM / IP Logged
Audiovox lists WHITE/ purple (+) in passenger kickpanel with 1.6k resistor, and my other source is WHITE/ brown (-) with 2k resistor at switch.
todds440
Member - Posts: 48
Posted: December 18, 2009 at 6:54 PM / IP Logged
Thanks guys.  Did install today , 1.6 used a relay works great!  Thanks again.
