autopage rs 750 lcd
CraigC
Member - Posts: 16
Posted: April 06, 2003 at 9:28 PM / IP Logged
I just finished installing the alarm in my 92 bmw 535I, I try to program it and the alarm does not go into the program mode. Where would I find the owners, install and lcd remote manuals?? I have misplaced them some where and I can't find them.
thankx
Platinum - Posts: 12,488
Posted: April 06, 2003 at 9:51 PM / IP Logged
Autopage 750LCD User Manual
Autopage 750LCD Installation Manual
jrilla
Gold - Posts: 1,498
Posted: April 06, 2003 at 11:54 PM / IP Logged
Did you install the siren yet? Is the antenna plugged in? I know these are trivial questions but they need to be asked. The siren (or horn) is the only way to know if you have entered programming mode. Does everything else work fine? Actually you shouldnt be able to remotely start the vehicle if you have never entered programming mode. look through the manual and get back to us.
J Rilla
Owner/Installer
CraigC
Member - Posts: 16
Posted: April 07, 2003 at 3:32 AM / IP Logged
everything is hooked and the alarm works great but I haven't been able to get the remote start to work. I will look at the manual and see what I am doing wrong. I press the valet switch and the is no chirp, if that helps
CraigC
Member - Posts: 16
Posted: April 07, 2003 at 4:01 AM / IP Logged
When I push the stat button on the remote, the lights flash on the remote(the marker lights) but no ignition or anything
jrilla
Gold - Posts: 1,498
Posted: April 07, 2003 at 10:16 AM / IP Logged
Like I mentioned before, you need to enter programming before it will even try to remote start. Look in the manual at the start feature II programming. Select voltage checking type and then try to start the car. Read the manual carefully for that section and then go try it. Make sure when you press the valet button that you get a clean press and release because the button can be difficult to press cleanly. Remember you need to turn the key on/off, on/off, on/off. So start and end in the off position, then press the button 10 times and on the 10th time hold it until you hear the siren. If the siren doesnt sound after three seconds or so then try again.
J Rilla
Owner/Installer
cool_greg
Copper - Posts: 125
Posted: April 07, 2003 at 5:17 PM / IP Logged
sounds like a problem with the neutral saftey switch not being grounded, had this problem a while back and it had me stumped for a while until I checked everything over
Greg
securinu
Silver - Posts: 772
Posted: April 07, 2003 at 6:08 PM / IP Logged
The BLACK/ white wire on mini black connector  must be grounded, otherwise it will not start.
Joe O'Byrne
Owner / Installer
CraigC
Member - Posts: 16
Posted: April 22, 2003 at 4:38 PM / IP Logged
I finally got everything to work great,but after a couple weeks of the unit working great the does not lock or unlock the doors, it just did it suddenly. any ideas???????
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
