avital 5303l
tedmond
Gold - Posts: 4,610
Posted: January 12, 2010 at 4:59 PM / IP Logged
damn, a compustar pro with start/keyless combo 2way is only 400 bucks installed with fortin bypass. remember this is canadian dollars too ahah.
Ted
Compustar Expert
chev104275
Gold - Posts: 1,436
Posted: January 12, 2010 at 5:17 PM / IP Logged
I shouldnt say never used t-taps when i first started 7 years ago i used them on the lincoln LS ing wiring harness. But now i strip about an inch of insulation from the middle of the wire stab a hole in the middle and run the new wire through the hole and then somtimes solder depends on of the customer is in the waiting room or not   i always solder atleast the tach wire though
nanohertz
Member - Posts: 12
Posted: January 28, 2010 at 9:15 AM / IP Logged
Thanks for all your input guys, I have a 08 Infinite FX35, I've heard prices as high as 600 for the same thing, but also i was wondering is the remote start really worth it, and also is there a big difference in the standard lcd two-way pager alarms, and the color touch screen two-way alarms, and if so what might they be, and in the collective wisdom of this thread would you guys recommend one over the other, thanks.
nanohertz
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
