viper 5301 dlpkgm xprsskit 2001 tahoe
blizz2005
Posted: January 24, 2010 at 4:19 PM / IP Logged
well where to start. past 2 days been installing this viper remote start and been having problems. horn honks thats about it
tyler armstrong
ntman
Member - Posts: 12
Posted: January 24, 2010 at 6:21 PM / IP Logged
Heres a good starting place, it helped me out quite a bit. instructions for a trailblazer but GM wiring is similar on all trucks
http://forums.trailvoy.com/showthread.php?t=65742
yimke
Copper - Posts: 417
Posted: January 24, 2010 at 10:59 PM / IP Logged
Sounds like you need to take it to a pro. We can't help you with such limited info you provided us.
When you remote start it, does it actually light up the dash, or does it give you clicking sounds?
When remote started does a lock on the dash appear? Does it even crank?
Are you locks working? Is your GWR wire connected from the remote start?
blizz2005
Posted: January 25, 2010 at 3:14 PM / IP Logged
  1. RED / white   (-) 200ma trunk release output
  2. red  (+)  12vdc constant input
  3. brown (-) horn honk ouput
  4. WHITE/ brown light flash isolation wire
  5. black (-) ground
  6. violet (+) door triger input
  7. blue factory horn input
  8. green (-) door triger input  n/c  or n/o
  9.  BLACK/ white (-) dome light output
  10. WHITE/ blue(-) remote start/ tutbo timer activation input
  11. white parking light output
  12. orange(-) ground when armed output
H2
  1. light GREEN/ black factory alarm disarm output
  2. ORANGE / black aux 4 output
  3. GREEN / WHITE factory alarm arm output
  4. violet/black aux 2 ouput
  5. WHITE/ black aux 3 output
  6. WHITE/ violet aux 1 output
  7. gray/black diesal wait to start
  8. empty
  9. violet/white tack input
  10. dark/blue status output
  11. pink/white flex relay control output
  12. orange axxesory output
  13. purple starter output
  14. pink ignition  1 output
  15. grey hood pin
  16. blue/white 2nd statis / rear defrogger output
  17. brown (+) brake shutdown input
  18. BLACK/ white  neutral safty input
H3
  1. pink ignition 1 input/output
  2. RED / white fused (30a) ignition 2 flex relay input 87
  3. orange accesory output
  4. violet starter output
  5. red fused (30a) igniton 1 input
  6. pink/white ignition 2 / flex relay output
  7. pink/black flex relay input 87a key side  if required
  8. RED / black fused (30a) accessory/ starter input
http://www.bypasskit.com/getdocument.aspx?documentid=2000
ntman
Member - Posts: 12
Posted: January 25, 2010 at 3:42 PM / IP Logged
This is the wiring I used on my suburban, it took me a total of 4 hours from open door to finished first time install I have the python 872 which is basically the same unit marketed under a different name.
I used D2D connector you might have to go W2W with a 2001
Just remember that you need to program the alarm before it will work correctly. I forgot to do the programing and car wouldn't start until I got help on here and programed the alarm from manual transmission mode.
Wiring:
H1 RED / WH - NC
H1 RED - +RED IGN
H1 BROWN -SIREN (WORKING)
H1 WHITE/ BR - NC
H1 BLACK - GROUNDED TO METAL
H1 PURPLE - NC
H1 BLUE - NC
H1 GREEN - DLPKGM DOOR TRIGGER
H1 BLACK/ WHT - NC
H1 WHITE/ BLUE - NC
H1 WHITE - NC
H1 ORANGE - NC
H2 - NOT PLUGGED IN
H3 PINK - IGN PINK & DLPKGM TAPPED OF THIS WIRE
H3 RED / WHT - IGN RED / WHT
H3 ORANGE - ORANGE ACC
H3 PURPLE - YELLOW STARTER (STARTER SIDE)
H3 GREEN - YELLOW STARTER (KEY SIDE)
H3 RED - IGN RED
H3 PINK/WHT - IGN SWITCH WHITE
H3 RED / BLK - IGN RED
RS IN
BLK/WHT - GROUND TO METAL
PURPLE - TACH LEAD DLPKGM
BROWN - WHITE BRAKE PEDAL WIRE
GREY - HOOD PIN
BLUE/WHT - NC
RS OUT - NOT PLUGED IN
DOOR LOCK - NOT PLUGGED IN
DLPKGM
D2D - 872 LE D2D
PINK - PINK IGN
GREEN - GREEN DOOR TRIGGER 872 H1
PURPLE / WHT - 872 TACH RS-IN
blizz2005
Posted: January 26, 2010 at 10:33 AM / IP Logged
H3   not used
H3 RED - IGN RED
H1 RED / WH - NC
H1 RED - +RED IGN
H1 WHITE/ BR - NC
H1 PURPLE - NC
H1 BLUE - NC
H1 BLACK/ WHT - NC
H1 WHITE/ BLUE - NC
H1 WHITE - NC
H1 ORANGE - NC
  1. light GREEN/ black factory alarm disarm output  to green
  2. ORANGE / black aux 4 output n/a
  3. GREEN / WHITE factory alarm arm output n/a
  4. violet/black aux 2 ouput n/a
  5. WHITE/ black aux 3 output n/a
  6. WHITE/ violet aux 1 output  n/a
  7. gray/black diesal wait to start  n/a
  8. empty
  9. violet/white tack input  to tack in ecm
  10. dark/blue status output  to dlpkgm
  11. pink/white flex relay control output n/a
  12. orange axxesory output n/a
  13. purple starter output n/a
  14. pink ignition  1 output  goes to pink in dlpkgm
  15. grey hood pin  hood pin
  16. blue/white 2nd statis / rear defrogger output  n/a
  17. brown (+) brake shutdown input  white on brake
  18. BLACK/ white  neutral safty input  ground
Then its in manual transmition mode so hafe to change to auto,   and started right up after I did this.
far as paying 400. bones for this u would think they would put in relays for the doorlocks.
blizz2005
Posted: January 26, 2010 at 10:38 AM / IP Logged
Thanks for your help, its been 20 hrs for my first install and works great . next  time 5 hrs lol Thanks again
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
