2008 jeep patriot problems
civic_tt
Member - Posts: 22
Posted: February 01, 2010 at 3:05 PM / IP Logged
2008 Jeep Patriot
DEI 591r  xpresskits xk532
Remote start works fine.  Randomly locks doors, flashes hazards and honks horn while driving.  Has anyone seen this before.  Seems like xk532 is setting off factory alarm?  Any fixes or suggestions are appreciated.
Thanks ERIK
tedmond
Gold - Posts: 4,610
Posted: February 01, 2010 at 3:41 PM / IP Logged
you have it wired up at d2d or w2w?
check your ground connections. a bad ground leads to many erratic problems.
Ted
Compustar Expert
civic_tt
Member - Posts: 22
Posted: February 01, 2010 at 4:44 PM / IP Logged
It is wired W2W. I will check ground and move it. Thanks
themobileguru
Member - Posts: 9
Posted: February 01, 2010 at 7:46 PM / IP Logged
Definitely a bad connection. Bad Ground being the most common....also could be a problem with 12V connection/voltage not being constant.
civic_tt
Member - Posts: 22
Posted: February 01, 2010 at 7:49 PM / IP Logged
Another thought this all started when I began to make connections to the igntion harness. I can't rememder if it was the ignition or MUX wire. I don't know if this helps.
themobileguru
Member - Posts: 9
Posted: February 01, 2010 at 7:58 PM / IP Logged
What wire do you have the 12V connected to? Red or RED / Orange...or other? The RED / Orange 12V wire is rated at 10amps...aka, you should find a different source (the battery, or Red wire at the TIPM..The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender.)
civic_tt
Member - Posts: 22
Posted: February 01, 2010 at 8:04 PM / IP Logged
12volts is connected in the harness. I thought about it moving it after the problems. I will move it to a better spot. Thanks
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
