how to change factory jbl hu to diff hu?
full foot notch
Posted: February 15, 2010 at 1:32 AM / IP Logged
hey guys, bought a 98 towncar signature with the JBL factory setup in it, only reason i knew was that i had noticed the JBL on the speaker grill. well i have a nice kenwood single DIN CD player with direct USB plugin and bluetooth capability and would like to replace the factory radio. i was originally going to go with a double DIN indash video but ive heard apparently you have to do modifications to the dash behind the radio.
so my first question is, does this JBL system qualify as the premier or audiophile system they speak of in different place. my second question is can i just do a plug and play in the dash area, or am i going to have to completely rewire the system like you have to with the 96 and up taurus's with the football dash , IE where you have to buy the $75 harness and run it from the trunk up to the front dash or is it a simple find the factory amp and use a bypass harness like with the earlier ford explorers(which was on the right rear side and just had to plug the harnesses together to bypass the amp.
tommy...
Gold - Posts: 1,901
Posted: February 15, 2010 at 8:53 AM / IP Logged
Search Results
Click part for more detailed product information.
how to change factory jbl hu to diff hu? -- posted image. Metra Electronics Corp. 70-1771
Ford/Lincoln/Mazda 1998 - Up Into Car 16 PIN...If NO factory amp...
how to change factory jbl hu to diff hu? -- posted image. Metra Electronics Corp. 70-5516
Factory amplifier integration harness...If equipped with a factory amp...
Search Results
how to change factory jbl hu to diff hu? -- posted image. Metra Electronics Corp. 95-5817
Ford/Lincoln/Mercury/Mazda DDIN Multi-kit
how to change factory jbl hu to diff hu? -- posted image. Metra Electronics Corp. 99-5600
Ford Ranger/Explorer 95-Up
how to change factory jbl hu to diff hu? -- posted image. Metra Electronics Corp. 99-5802...The sides of this kit break super easy...OK once its mounted...
Ford Multi-Kit 95-Up
M.E.C.P & First-Class
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
