2008 f 250 remote start
wooddogg
Member - Posts: 14
Posted: February 15, 2010 at 2:09 PM / IP Logged
looking or info on data wires on 2008 ford f 250 diesel,,,, i datalink locations are not accurate either is audiovox,or peripheral,any help?
x1le
Copper - Posts: 171
Posted: February 15, 2010 at 3:35 PM / IP Logged
should be PURPLE / white and yellow/black coming from the ignition cylinder.
http://bypasskit.com/getdocument.aspx?documentid=2077
wooddogg
Member - Posts: 14
Posted: February 19, 2010 at 12:22 PM / IP Logged
thx will try those
Moderator - Posts: 12,488
Posted: February 20, 2010 at 8:57 AM / IP Logged
iDatalink information is correct. You just have not found the correct wires at the steering column. Remove the shroud and this will be easier to find the wires at the PATS module. Otherwise if you know what wires to meter ( VIOLET/GRAY & YELLOW/RED ) you will find these wires in the group of wires running from the steering column.
wooddogg
Member - Posts: 14
Posted: February 23, 2010 at 4:25 PM / IP Logged
have located wires but think the production date is an issue from what i understand
Posted: February 23, 2010 at 5:40 PM / IP Logged
Any pre 2008 doesn't have PATS for the Super Duty's. If this is the new body style SD, then it doesn't matter on the build date. There are two of each one of the wires that I listed in the harness, that is why I suggested to go straight to the PATS module instead. There you will find the RX and TX wires without having to guess if you have the correct ones.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
