viper 5901 h2 harness
punizzle
Member - Posts: 10
Posted: February 20, 2010 at 10:51 PM / IP Logged
I know this is going to sounds really dumb and noob like but I can't seem to find the 2nd unlock wire on the 1 pin harness.
In the install manual it says it's a "Light Blue" H2/6. I understand that on the new system the Remote start input and output and h2 harness are connected into one 1-pin harness now?
viper 5901 h2 harness -- posted image.
That's what my 1-pin looks like. What pin on that harness corresponds to the 2nd unlock wire
punizzle
Member - Posts: 10
Posted: February 21, 2010 at 11:25 PM / IP Logged
bump.
Any help anybody?
I have the relays all wired up. I just need to find this 2nd unlock wire.
fredddy9
Member - Posts: 40
Posted: June 30, 2010 at 12:24 PM / IP Logged
i run into the same issue, according to online installation manual:
http://www.directeddealers.com/manuals/IG/Viper/N5702V_2008_08web.pdf
H2 is 8pin harness, while Viper 5901 paper manual shows 18pin, and no 2nd unlock (?)
Posted: June 30, 2010 at 4:55 PM / IP Logged
Use a spare aux for this function.
t&t tech
Platinum - Posts: 2,622
Posted: June 30, 2010 at 9:17 PM / IP Logged
Yes as howard said the spare auxiallaries can be programmed to perform second unlock function!
fredddy9
Member - Posts: 40
Posted: July 02, 2010 at 1:31 PM / IP Logged
thank you for your replies, i'll hook it to h2/6 then
fredddy9
Member - Posts: 40
Posted: July 12, 2010 at 4:21 AM / IP Logged
One more question regarding this topic.   According to the PDF manual there is a reverse polarity on LOCK UNLOCK
blue   (-) unlock (+)lock
green (-) lock (+)unlock
but according to tha PAPER diagram (first post) it only supplys (-), which is actually true with my Viper. At first i wired everything assuming i have (+) positive outputs and then had to add additional relays.
Can anybody confirm this behavior? that new units only have negative outputs?
fredddy9
Member - Posts: 40
Posted: July 12, 2010 at 4:26 AM / IP Logged
And also it would be much better if 2nd unlock was activated after pressing UNLOCK button the second time.    Weired that they haven't implemented this, in such a sophisticated alarm.
cobraguy
Member - Posts: 26
Posted: July 12, 2010 at 9:10 AM / IP Logged
That option is definitely there with the 5901 prior to the 18 pin harness. I can't help but think the Bitwriter would allow you to program an aux output the same way. As long as the vehicle you are working on has the ability to have the driver's door unlock separate from the rest, (separate relays) then you should be good. I know I've used this feature a few times.
t&t tech
Posted: July 12, 2010 at 4:50 PM / IP Logged
Yes the new units only have negative outputs! Also the unit does second unlock when you press the unlock button twice, dei do make mistakes sometimes, but they aren't unreasonable, lol!
