how to make a voltage divider
cabron19
Member - Posts: 15
Posted: March 03, 2010 at 1:49 AM / IP Logged
Can anyone please tell me how I can make a simple voltage divider?
Apparently I will be needing a 10:1 and a 20:1 divider.
A step by step explanation of the process would be so appreciated!
I am proficient with a soldering iron and working with most through hole components so I am fairly sure I can build the damn thing if I just knew how.how to make a voltage divider -- posted image.
Thank you in advance for any help.
anonymous1
Copper - Posts: 151
Posted: March 03, 2010 at 2:05 AM / IP Logged
If you don't mind . . .
Is this for DC or AC?
What voltage are you stepping down from > to?
Do you know what the current draw will be?
There are probably some IC or Voltage Regulator solutions readily available.
On the whole, what is it that you want to accomplish?
oldspark
Gold - Posts: 4,913
Posted: March 03, 2010 at 2:34 AM / IP Logged
AC or DC? how to make a voltage divider -- posted image. (I'm assuming this is NOT for 120V AC etc, but some SAFE voltage!)
If so, see http://en.wikipedia.org/wiki/Voltage_divider.
Then find the current from V=IR => I=V/R
Then each resistor's power from P=VI & V=IR => P=IIR (ie, I x I x R).
All units are volts, amps, ohms & watts.
Else volts, mA, k-Ohms & mW.
cabron19
Member - Posts: 15
Posted: March 03, 2010 at 3:38 AM / IP Logged
here is a link to what I am trying to do.
http://www.diymobileaudio.com/forum/diyma-tutorials/51435-setting-gains-w-o-oscilloscope.html
oldspark
Gold - Posts: 4,913
Posted: March 03, 2010 at 4:09 AM / IP Logged
So would this device work.....?
cabron19
Member - Posts: 15
Posted: March 03, 2010 at 4:15 AM / IP Logged
as in one resister? smarta**
j/k. how to make a voltage divider -- posted image.
But seriously I can accomplish what I want to do with one friggin resister?
oldspark
Gold - Posts: 4,913
Posted: March 03, 2010 at 5:09 AM / IP Logged
A potentiometer is a variable resistor is a voltage divider.
What impedance (resistance) do you need? Or what is the circuit's input/output impedance.
EG - if it's 10kR (10 k-Ohm = 10,000 Ohm) and you need 10:1 out, you could have two resistors: 9kR on top, 1kR on the bottom.
Or you could have a 10k pot (potentiometer; and linear!) dialed at 10% of it's sweep.
A pot is aka a volume control.
In the above diagram, the (say) 10V input is connected to gnd (bottom) and the top resistor (ie, from the left).
The 1V output is take from gnd (bottom) and the center-tap - ie, the bottom resistor out to the right...
cabron19
Member - Posts: 15
Posted: March 03, 2010 at 5:25 AM / IP Logged
Actually I think I finally found what I was looking for:
oldspark
Gold - Posts: 4,913
Posted: March 03, 2010 at 6:29 AM / IP Logged
But you said 10:1 - not 11:1? how to make a voltage divider -- posted image.
Funny though - otherwise it looks so similar to everything above.
Maybe that's just me..... Maybe you were right, I am smart...
Remember to crank the amp up.
And use 1/2W resistors, they can be more stable.
And will last twice as long as 1/4W resistors in this case. how to make a voltage divider -- posted image.
Wednesday, November 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
