689m 2000 f150
chev104275
Gold - Posts: 1,436
Posted: March 14, 2010 at 5:32 PM / IP Logged
it is an alarm so wiring it like that will cause the alarm to go off all the time
i was thinking of using a relay to open up the starter wire coming from the remote start
pin 30 to either side of the cut starter wire
pin 87 to the other side of the starter wire
pin 85 to the N/S wire of the 689M
pin 86 to trucks ing wire
so the only way the starter wire will be able to start the truck is when the 689m puts ground to the relay and ing from the truck
what do you think ?
tedmond
Gold - Posts: 4,610
Posted: March 14, 2010 at 6:03 PM / IP Logged
that would work as well. However i never dealt with asianwolf units. Does it crank 3 times and if all fails it turns off?
if so it should be ok.
Ted
Compustar Expert
chev104275
Gold - Posts: 1,436
Posted: March 14, 2010 at 6:24 PM / IP Logged
im not sure as far as i know it does it always starts on the first try (i have Tach hooked up) i never dealt with asianwolf before this one i havent had any problems with the system im not really that impressed by it though i think im going to give it a try it seems like it will work
thanks for your input tedmond
