Color code for 2002 Sonata
Riceyoung
Posted: April 11, 2003 at 3:00 PM / IP Logged
Please help me obtain the color code for my deck. Thanks.
esmith69
Gold - Posts: 1,511
Posted: April 11, 2003 at 10:12 PM / IP Logged
If you're just adding an aftermarket deck you should use a wiring harness instead.  Makes things so much easier and takes the guesswork out of everything.
Hyundai wiring info is not all that common online and this was the only thing I could find:  https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Hyundai&model=Sonata&ID=18034&type=Stereo
it's for 2000 so it might or might not apply to your vehicle as well.  You can certainly use it as a starting point to testing the wires with a DMM (which you should do anyways).
