door locks, 1996 dodge ram
b1mmuo27
Member - Posts: 37
Posted: March 17, 2010 at 7:11 PM / IP Logged
I don't know if I'm goofy but I can't remember how to do this. I set up my Sprinter 4 years ago this way. Now I have a 1996 Dodge Ram pickup. It was broken in 2 weeks ago so I decided to install an alarm. That went ok but I am trying to tie the power door locks to the alarm. There is no remote for the truck so I am trying to wire it to the alarm. I have 2 relays. One for lock the other for unlock. I am using the pulse from the alarm to lock & unlock. Not working. I tie the pulse from the alarm to the coil on each relay & run 12V through the normally open contacts. The 12v through that contact pulses to the door lock/unlock. Not working. What did I miss?
tedmond
Gold - Posts: 4,610
Posted: March 17, 2010 at 8:08 PM / IP Logged
you need 2 relays and 2 resistors
820 ohm - lock
330 ohm - unlock
set up relay like so, just make one as lock or unlock
85 - negative output from alarm
86 - constant 12v
87 - chassis ground
30 - lock or unlock wire with proper resistor inline.
Ted
Compustar Expert
b1mmuo27
Member - Posts: 37
Posted: March 17, 2010 at 8:26 PM / IP Logged
Thanks I'll try that tomorrow. I am an electrician for 28 years & we thought that the relays were as follows:
85 coil
86 coil
30 common
87a normally open
87 normally closed
tedmond
Gold - Posts: 4,610
Posted: March 17, 2010 at 10:03 PM / IP Logged
you just have 87 and 87a mixed up. here you go.
https://www.the12volt.com/relays/relays.asp
Ted
Compustar Expert
b1mmuo27
Member - Posts: 37
Posted: March 17, 2010 at 11:15 PM / IP Logged
Yes I see I did a boo boo. Why the difference in resistance on the lock & unlock lines? Thanks
blanx218
Silver - Posts: 654
Posted: March 17, 2010 at 11:43 PM / IP Logged
dont wanna cause any confusion but a 96 ram has 5wire locks in any info i have. that would mean wire youre relays as follows:
cut each of the lock - ORANGE / purple   unlock - pink/purple
pins 85 & 87 -    +12 volts
pin 86 - lock or unlock (-) output from the alarm
pin 87a - switch side of the lock/unlock wire
pin 30 - motor side of the lock/unlock wire
tedmond
Gold - Posts: 4,610
Posted: March 18, 2010 at 6:20 AM / IP Logged
blanx could be right as well.
but since its a canadian model truck, i have done one and it was multiplexed (using resistors)
to the OP, the differance in resistance controls the voltage read by the computer. the one wire systems aka multiplex.
Ted
Compustar Expert
Posted: March 18, 2010 at 7:18 AM / IP Logged
Just to add to the general level of ignorance, I was doing a lot of Cherokees up to 95 and they had a pos. trigger, the relays were in the under dash relay module, at least that's where they were in the right hand drive version built by Steyr in Austria Doh door locks, 1996 dodge ram -- posted image.
b1mmuo27
Member - Posts: 37
Posted: March 18, 2010 at 10:11 AM / IP Logged
I hear what you say about multiplex. My Sprinter had a CANBUS system in it. This old '96 is straight analog. The only computer in it is the antilock brakes & TPS switch. It's a diesel so it's pretty simple.
Posted: March 18, 2010 at 10:53 AM / IP Logged
Don't confuse multiplex with the CAN they are completely different beasts!
Actually the Sprinter only went CAN from about 07. I did an 06 last week with no references to any strange electrics
