fortin bypass, viper 5701, 06 tacoma
davidletran
Posted: March 22, 2010 at 4:50 PM / IP Logged
I have a 2006 Toyota Tacoma double cab v6 thanks
I have a viper 5701 and trying to install the alarm myself. I installed alarms on a few cars but never with a keysense.
I tapped into the lock (purple) and unlock (GREEN/ black) wires from the kick panel but when i arm or disarm the locks dont engage.
I also have a Fortin KEY-OVERRIDE-SL2 box but the instructions that came with it is garbage. where is the data in and data out wires?
Does my truck have a data link box? and if so, the fortin override came with a plug that suppose to plug into the datalink box?
Here is the link to the fortin installation instructions.
https://ifar.ca/download/1846/key-override-sl2_installation_guide.rev-z.pdf
thanks guys , God bless
tedmond
Gold - Posts: 4,610
Posted: March 22, 2010 at 6:27 PM / IP Logged
the fortin pieces is prob one of the easiest pieces to install and program.
look at your ignition cylinder for a 7pin plug.
Pin 4 - rx
Pin 5 - tx
for the keysense wire, there is a 2 pin white plug that is at the ignition switch as well. The keysense is the wire next to the WHITE/ black
Locks - purple (-) @ dkp Pin 4 of 10pin plug
Unlock - GREEN/ black (-) @ dkp Pin 8 of 10pin plug
test the wires by turning the key in the driver door.
test the outputs of the unit to see if they work.
Ted
Compustar Expert
Sunday, October 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
